I cannot set password to database.
I sent error message.
Cannot set password
Re: Cannot set password
What's your EPIM version number? Please check if it's the latest one 11.2.5.
Installed newest version.
The same error.
The same error.
- error_log.txt
- (2.55 KiB) Downloaded 49 times
Try to sync your data over to the new database using EPIM Synchronizer (https://www.essentialpim.com/features/f ... nchronizer). Will it help?
It worked ! Thanks !admin wrote: ↑Tue Mar 14, 2023 3:39 pm Try to sync your data over to the new database using EPIM Synchronizer (https://www.essentialpim.com/features/f ... nchronizer). Will it help?
