I have had this problem before, but it was resolved. When I search for a word in a note, often the word isn't found even though it is definitely there. A search from the top level of the note tree for the same word does find it. See two screenshots attached to illustrate.
Epim Pro 11.2.4
Windows 10 Pro 64 bit
Problem with searching notes
- Been thanked: 2 times
- Has thanked: 1424 times
- Been thanked: 990 times
Re: Problem with searching notes
Please export the note into a new EPIM database file, open the exported file, check if the issue is still there and if yes, forward me the DB via PM here in the forum. Thanks!
For whatever reason, this no longer seems to be a problem. Maybe following the latest release?
If it returns I will report it again.
Thanks for the help.
Good to know and thanks for the update.
Search does not work at all for me. It always comes up empty.
If I type a new note it works. But anything I imported from treepad is not found.
If I cut and re-paste an imported note it is then found.
What is your EPIM version number? Could you please send us a test note from TreePad so that we can attempt to reproduce the problem on our end?
