When EPIM is open icon on taskbar underlined in blue and sticky note on screen. When I minimise EPIM:
(1) the sticky note stays on screen (good)
(2) the EPIM taskbar icon stays but no blue underline.
(3) when I click on the icon to view EPIM it takes time – about 6 secs – to re-appear.
Other task bar minimised programs restore on screen at once. Why the delay with EPIM?
Have I got some EPIM setting wrong?
EPIMPro minimise to taskbar error.
- Christopher Whitmey
- Has thanked: 40 times
- Been thanked: 10 times
Re: EPIMPro minimise to taskbar error.
Will there be any change if you first minimize and then maximize EPIM and:
- there's no sticky note involved or
- you do that when any other EPIM's module (not Notes) is active?
Thanks admin for speedy response.
1. minimize when maximize EPIM on screen = still no blueline and 6 secs.
2. sticky note made non-sticky then minimised = still no blueline and 6 secs
3. no other EPIM's module (not Notes) open and showing max. calendar in full screen then minimise = still no blueline and 6 sec
EPIM Pro 11.2.4 Lifetime: Windows 10: Andoid EPIM 6.0.10
Problem solved. I went to EPIM>Tools>Options>General and ticked Minimize to System Tray. Then when I minimized an icon with blue underline appeared in the System Tray (ST). When clicked EPIM opened at once to last screen size. The Taskbar icon was still present with no blue line and when clicked took about 6 secs to open. A day later I decided to untick the ST Minimize to ST button. ST icon now gone but the Taskbar icon now has a blue line and opens at once!
