Send / Receive Mail: Connection Closed Gracefully
- Has thanked: 28 times
- Been thanked: 11 times
Re: Send / Receive Mail: Connection Closed Gracefully
Admin: Thanks for that. People keep automating things. What does setting up the account again do?
- Has thanked: 1418 times
If you do that with a working IMAP account, it wouldn't do anything. If IMAP isn't working - let's see why. This cannot be discussed without actually having a specific case in mind.
It never is. A debugging technique is the log files.
Still looking for someone with ideas. I did try the send / receive again and found that the send works fine, the receive does not. It still gives a "connection closed gracefully" error.
Please contact you email provider about the issue, as the error is likely on their end as that's the server which closes the connection.
