Notes Margins
- ecsaltz
- Has thanked: 30 times
- Been thanked: 78 times
Notes Margins
I greatly appreciate the newer feature of margins in the Notes module, but I have a problem with setting the right margin. Once the right margin is set in a note, it also resets the right margins in all past notes and thus reformats those notes to fit the new right margin - not a desired effect. I use two printers with WinEPIM, one with narrow paper, the other with wide paper, and I set the right margin in a note to reflect which width printer I will be using. So now, I have to frequently reset the right margin to reflect the printer I use. Would it be possible for each note to retain the right margin set for it? Or at least, if the right margin is a global setting, a way to override that setting on a per note basis?
- Has thanked: 1418 times
Re: Notes Margins
That's an interesting observation, thanks for bringing it to out attention. Will try to improve the default behaviour in one of the nearest EPIM versions.
