Multiple selection note tab
daho2018
Has thanked: 15 times
Been thanked: 7 times
Post by daho2018 »
I often use the tabs within a note. Due to my structure, I move certain tabs into different folders. Since you can only move one tab at a time, it takes a long time.
Hence the idea of being able to select several tabs.
Greetings
Re: Multiple selection note tab
Thanks, noted!
