Private Items showing
Argenthos
Has thanked: 28 times
Been thanked: 6 times
Post by Argenthos »
I have some private items, trees and leafs with some info and on the security options tab i have turned on the options to lock and hide all when minimizing or switching module.
On older versions it worked as intended, i quited EPIM or switched modules, epim would hide and lock everything. Now, if i quit epim while working in the private items and open up epim again, it shows the hidden tree with the name, but not the content, it is properly locked.
Is this a bug?
Re: Private Items showing
Thanks for the report, will address the issue in the next update.
