I reported this long ago, and thought it was handled. It wasn't. I'll private message the source code of one message that gets sorted wrong. So, here's the issue: Sometimes, some messages get sorted incorrectly when grouped - View / Layout / Classic view grouped. - The same messages are sorted correctly if classic view not grouped.
It doesn't matter if the sort is done by received or Date. Here's an example.
You'll notice that the three messages from Firetrust Support are sorted in the wrong day! Everything else sorts right. If I sort on the Date column, the same result. However, if I don't group, it sorts properly. Incorrect sorted of grouped messages seems consistent by sender, but is rare.
Again, I'll personal message the actual source of one of these mis-sorted messages.
Return of bad sorts
- Has thanked: 27 times
- Been thanked: 11 times
- Has thanked: 1412 times
Re: Return of bad sorts
Thanks for the report, will have a look at it.
