I searched the forum but could not find anything similar. So I propose my idea. I very often use filters in the calendar module in the table view for different types of analysis. Every time I have to set these filters again and again. It would be very helpful if I could save the filter settings in some kind of preset that I can easily recall.
In Excel there is such a feature called "benutzerdefinierte Ansicht" (German), in English something like "user defined views" or "custom views".
Maybe such filter presets could be used in other modules as well.
Thank you and keep up the good work
a satisfied EPIM user
Saving filters as presets
- Has thanked: 1424 times
- Been thanked: 990 times
Re: Saving filters as presets
You can already do that by saving your custom filters as templates and then reusing them later. Please see the screenshot below.
- filter_templates.png (7.46 KiB) Viewed 1076 times
Thank you. This is exactly what I need. I didn't see the "custom view" because the corresponding option was turned off.
