Hi, I have been using Desktop/Android mobile ePIM for many years now and am very happy with it, synching usually works very well, but I have just noticed that some of my desktop categories in Calendar have not mirror synced to my mobile.
For example if I have an event on my desktop calendar showing in 'category a', and 'category a' does not exist on the mobile, then the event is synced to 'category b'. I sync two ways, use 15 different categories on my desktop, I see now there are only 14 categories on the mobile and some of them have different descriptors to the desktop. I am sure at one point they were all the same.
I would like the mobile app to emulate the desktop when it comes to categories, is it possible to do this?
Thank you, Lisa
Categories not synching
- Has thanked: 1418 times
Re: Categories not synching
Please make sure you have the latest AEPIM 6.0.10 version. Then do the following:
- backup your AEPIM and WinEPIM data
- uninstall AEPIM and reinstall it back in
- in Windows EPIM remove AEPIM synchronization and create a new one
- synchronize
- check if everything's working as it should now and let us know
Thanks!
- synchronize
Thanks!
Thank you Admin,
Worked like a charm, should have thought about a re-install before bothering you!
