Application error
Re: Application error
Unfortunately there is something wrong again!
Sending the picture and recorded video of the bug!
https://mega.nz/file/MDgy0LoJ#ePSjFU-AQ ... yZQtdtfxsU
https://mega.nz/file/oDARgAoT#9V4RfRaQo ... JXl6lNzXmk
Hope you can fix it!
Sincerely
Here I have recorded how the error comes up.
After that it is not possible to use or turn off the programs!
https://mega.nz/file/FfRiyZZY#AtrutSOsJ ... 5IWZCtVIks
- Has thanked: 1418 times
Should be fixed in the 11.2.3 version. Please update.
In the calendar, in every day, there are strange characters in the attached file.
They look like Chinese characters and is there any way to get rid of them?
- konstiga_tecken.jpg (1.19 KiB) Viewed 3077 times
- konstiga_tecken2.jpg (1.36 KiB) Viewed 3077 times
Tools->Options->Calendar, make sure the "Enable Chinese Lunar calendar" option is disabled.
Notes are not fully displayed in windows, only in a part of windows, and the rest is blank, according to the attached video.
Is there a way to show the note in full, please?
https://mega.nz/file/gXYmyQZa#0w6anE1Xf ... UjMIgsSoTQ
A folder, and all subfolders, have been locked, in a strange way, and how would one unlock them, as per the attached vide, please?
https://mega.nz/file/ofRFwKRB#MWmDgAL83 ... Big11zPKxs
We're unable to reproduce this. Please check if the same is going to happen on a new DB, as well.
You need to select a note first (click on it).A folder, and all subfolders, have been locked, in a strange way, and how would one unlock them, as per the attached vide, please?
Right from the start, PDF files are not displayed the same way. Most often they are not displayed in full window and very rarely they are displayed correctly in full window.
Have created a brand new database and it appears the same!
Don't know what causes it?
I have recorded how it works with viewing notes!
It would be much better if notes can cover the whole window!
https://mega.nz/file/RKI33QZY#rB_FWUNoR ... nKwpQ34Jiw
https://mega.nz/file/xPJBwLiC#aWZfYNv6V ... iAbEyAYn74
I see what you mean now, thanks for the video. This is a feature suggestion, will consider implementing it.
It would be perfect if you could fix the zoom function that Nitro PDF Pro has. I have recorded how it works with them and you can use different zoom options depending on whether you are looking for information in the file or if you want to read exactly any part of the file!
https://mega.nz/file/MfJljSjI#8CY8vM7W1 ... 7m9n2KV-Pc
Thanks for the suggestion, noted.
