Event Date Priority
Outdated
Event Date Priority
Post by Outdated »
I notice that when you have 3 or more events as All date, and the event names start with a number, The event will be in order of number sequence event if you put on the priority flags. Now once you put on the priority flags should not the events be in order of priority?
Re: Event Date Priority
Not necessarily. Although you can always manually sort the events the way you wish by drag&droping them.
Outdated
Post by Outdated »
Oh. That's convenient... Well keep up the good work fellas!!!
