Networking EPIM within the home
- Has thanked: 1418 times
Re: Networking EPIM within the home
You can also try to utilize the EPIM Server sync option (File->Synchronization->Add Synchronization->EPIM Server) if direct connection isn't working for you.
Maybe you should try posting the steps your doing in as many details as you can to help identify where you might be having an issue.
I personally didn't run into any issues while following the manual to get a shared network database running in my home.
