toolbar
lorymax
Been thanked: 7 times
toolbar
Post by lorymax »
A small thing, not very important, but convenient. I know I've written something similar before.
Since the toolbar is now customizable, don't you also find it useful to be able to have the selection of customized filters there, always available, instead of having to enable the customized view bar every time?
Has thanked: 1412 times
Been thanked: 984 times
Re: toolbar
There's a little pin icon on the left hand side of the toolbar that if pressed should make the toolbar always visible. Is that something you were looking for?
lorymax
Re: toolbar
Post by lorymax »
Yes, I know. But it is not preserved after restarting EPIM.
However it is a small unimportant thing, just a subtlety.
I confirm that even with the 11.2RC1, the way I use the software, I haven't had any problems. Great.
Thank you.
Re: toolbar
Looks like a bug then, will check it out and fix in the release version. Thanks for checking out RC1 and confirming it works fine for you! :)
