open ics file to import
ypim
Has thanked: 18 times
Been thanked: 8 times
Post by ypim »
Problem:
I have a website and there its possible to get/download an ics-file.
I click on "add to calendar" on the site then I have to authenticate on this website, and finally the Firefox dialog for downloading and "open with" appears. There I can now select EssentialPIM and hit OK.
-> Nothing done. No new appointment in EssentialPIM.
Could you help me?
Re: open ics file to import
Yes, when Firefox downloads the file, do not open it. Just save to a place where you know the file is. And then use EPIM menu File-> Import-> Calendar-> iCal to import that file.
ypim
Post by ypim »
Is it possible in future that I don't have to save the file?
Import it in essentialpim.
Then delete the file.
That's not a nice workflow. ;-)
So far not clear if many people use this feature (importing iCal files)
Byteworm
Been thanked: 4 times
Post by Byteworm »
I'm also interested for this feature.
Often I forward appointments as ics-file to my private mail account. If I simply could click on the ics-file to import it, this would be fine.
Until now I have to select the import dialog for each appointment :?
Kind regards!
ttepimform
Post by ttepimform »
How to import .ics to Android app or can it only be done on desktop? I have pro versions. Thanks
This is only possible with the desktop version so far.
