Task hierarchy messed up after sync over wifi
kdgdr
Has thanked: 9 times
Been thanked: 18 times
Post by kdgdr »
To reproduce:
  1. on a task tab that has a hierarchical tree of tasks, create some tasks in WEPIM in different branches of the tree ad random. For some tasks use "add as child" and for other tasks use "add as sibling"
  2. drag some tasks from their original branch to another branch
  3. sync over wifi between WEPIM and AEPIM
  4. you will notice that some tasks that you created or dragged to a different branch in WEPIM do not have the same/correct branch in AEPIM after syncing. most of them will have become root tasks in AEPIM, some might have become branch tasks in the wrong position in the hierarchy
Please fix, because it is a real hassle to manually correct positions in AEPIM + if you spend a lot of time correcting this, sometimes a new sync afterwards messes the hierarchy up again.
Has thanked: 1407 times
Been thanked: 977 times
Re: Task hierarchy messed up after sync over wifi
We're unable to reproduce this problem. Would you be able to reproduce it with a new db?
