Change text color and background
marmegint
Post by marmegint »
Hi there,
In the notes module of version 6.0.8, if I set the background of a text section to red and the text to white, then after saving, the white text changes back to black.
(Sony Xperia 1, Android 9)
Re: Change text color and background
Confirm this issue, will fix it in the next update.
marmegint
Post by marmegint »
Thank you.
Should be fixed in AEPIM 6.0.9. Would appreciate if you check it out when the new version reaches you and let us know.
marmegint
Post by marmegint »
It works perfectly.
Thank you for the quick help.
