Can't use Return key on Password Notes
unkoala
Post by unkoala »
I'm using EssentialPIM Free 11.1.10 on a windows 10 Pro
When i try to edit a note on the Password section the Return key (both on the standard keyboard and the keypad) doesn't work properly, it selects all the text on the note and nothing more.
When i create a new password the key works without problems, it's only when i try to edit the note.
I've created a new database with the latest version of the program and the issue persists.
Has thanked: 1411 times
Been thanked: 984 times
Re: Can't use Return key on Password Notes
Please forward us the test database file you created as we couldn't reproduce the issue on our side. Also, do you edit notes in a separate dialog window or using the lower section of the screen?
unkoala
Post by unkoala »
When i try to edit the Notes section of the password there's no separate dialog window.
I've attached the test database.
TEST.EPIM
(3.05 MiB) Downloaded 71 times
Double click on the entry to get a separate items editing window. The issue will be fixed in the next update, thanks.
