currently, the PC Version has a middle priority indicated by a " ~ " and a entry for no priority defined. On android, this priority level is missing.
It makes a difference, if a task is of medium priority or not assigned to a priority level at all.
Android and Win EPIM user cannot use "~" because it is mission on the mobile device. How can you proper sync different rages?
Any filtering to the "not defined* will end-up in listing the middle classified too.
Please correct it.
Dualuser
Same priorities in Windows and android.
- Has thanked: 1424 times
- Been thanked: 990 times
Re: Same priorities in Windows and android.
Medium priority in WinEPIM equals to "no prority" in Android EPIM.
'Well but is a differnce, if you had not assigned a priority or see it as medium.
Thanks, noted.
