Hello, good afternoon, is there a possibility for Epim android to be superimposed on other applications?
On my android 10 phone, if I snooze a notification alarm and open another app, that alarm is lost,
it only appears if I edit the notification again.
Epim 6.07 free.
EPim 6.07
Re: EPim 6.07
I'm not sure what you mean by saying the reminder is lost. If you snooze it, it gets snoozed and will only appear again after its time is due.
Re: EPim 6.07
Yes, this should be the normal behavior, but on this phone (Ulefone X7 Pro Android 10)
after opening any other App (for example Messages or WhatsApp) Epim does not repeat the alarm again , only after editing it again.
In Epim's application (information) menu there is no way to override them,that's why I asked if there is a way to do that.
Thanks for the quick reply
Re: EPim 6.07
Please check if there's still the bell icon for an item after you snooze its reminder.
Re: EPim 6.07
Yes, the bell appears, but something makes it not repeat the alarm, it could be the cell phone itself (android 10), if there was the possibility of EPim overlapping other applications it might solve the situation.
Re: EPim 6.07
Maybe you could also check if AEPIM has all the permissions it asks for in the system settings?
Re: EPim 6.07
Hello, Yes, it has all the permissions.
But it does not appear to overlap over the other applications.
I think this is the problem.
Re: EPim 6.07
A notification should appear in the status bar, it's not designed to overlap with apps. Thanks!
