​tag order: alpabetically (or manually)
kdgdr
Has thanked: 9 times
Been thanked: 18 times
Post by kdgdr »
Currently, tags seem to have no specific order in AEPIM. Please implement a sort order for AEPIM tags. Personally I don't need control over the sorting, so a hard-coded alphabetical ordering (a>z) would do the job for me.
Thanks in advance.
Kind regards.
Re: ​tag order: alpabetically (or manually)
The most used tags should be at the top. Although I don't see it happening. Will be fixed in the next update. Thanks.
kdgdr
Post by kdgdr »
Hi, thanks for providing a logical order in 6.0.5, however tag explorer is now very slow.
Maybe because it has to calculate number of items for each tag before it can show tags in correct order?
If that is the bottleneck, alfabetical order of tags might fix it, while also being more userfriendly IMHO.
Thanks for the feedback, will see if we can do some optimizations to Tags Explorer so that it loads faster.
