If you want to update a rule, it is necessary to find the rule from the list of rules. This is time consuming and tedious.
It would be a great enhancement if you could right-click a folder and choose to edit the rule which applies to that folder. Quick and easy.
Finding A Rule
- Has thanked: 1412 times
Re: Finding A Rule
You can search rules by their names in the Message Rules dialog window. There could be several rules for a folder and some rules may not include any folders at all (if you wish to assign a tag or automatically save attachments to a certain folder, for instance).
Re: Finding A Rule
I see, thanks for the suggestion.
