Sync Multiple Calendars
DavidN
Has thanked: 16 times
Been thanked: 11 times
Post by DavidN »
Is there a way to sync multiple calendars with the iphone?
Re: Sync Multiple Calendars
Not possible at the moment, although this feature will be added soon.
keith
Has thanked: 17 times
Been thanked: 7 times
Post by keith »
Will that be a facility to sync multiple Local calendars with AndroidEPIM, which will then
a) like WindowsEPIM show the separate Local Calendars? Or
b) will the WindowsEPIM Local calendars be merged to a single one in AndroidEPIM?
Either would be better for me than the present ability only to sync one Local calendar with AndroidEPIM. So if I have my events in my WindowsEPIM Local Calendar, and events where both my wife and I will attend in a separate WindowsEPIM Local Calendar, I can only sync one of these Local Calendars with my mobile, and the others remain on Windows only.
This discussion is for iOS EPIM, not the Android one. Although, there will be multiple calendars included in AEPIM, which corresponds to the point "a" in your question. Thanks.
keith
Post by keith »
That's good news (that my point a) will be covered). Many thanks.
Also ENORMOUSLY appreciate your efforts in responding to the many queries/comments you must get!! :D
VolkerM
Has thanked: 28 times
Been thanked: 5 times
Post by VolkerM »
Any idea when this feature will be implemented?
We cannot provide any ETA at the moment, unfortunately.
VolkerM
Post by VolkerM »
What a pity! Well, thanks so far...
