Hi there,
in 11.0.4 when clicking on a direct sync to edit in file menu (Android sync), I end up in setting of EPIMcloud sync.
This is an error which was there some versions ago. Now it's there again.
Please fix.
Jump to wrong sync
- Has thanked: 1418 times
Re: Jump to wrong sync
Unable to reproduce, unfortunately. Please check if this is going to happen on a new database, as well. Thanks.
- Has thanked: 10 times
- Been thanked: 31 times
You're right ... it's not there with a new database.
I remember, when this problem existed some versions ago, it was the same ... you could not repro and with a new DB I could not either.
As a matter of fact, this problem seems to come up from time to time. One can repro it with a certain DB (and ONLY with this DB), even if it is a fairly new DB (mine was created by version 11.0).
If you want, I delete all important data from DB and send the file to you, so you could see what happens and investigate DB.
Please do that, as we'll then be able to nail the issue quickly. Thanks!
