EPIM Syncing Key Constraint
simplynewt
Post by simplynewt »
I am now able to log into The Cloud after a couple days of failed attempts but now I am getting the following error or alarm:
violation of PRIMARY or UNIQUE KEY constraint "PK_SYNCINFO" on table "SYNCINFO" Problematic key value is ("IDUSER" = 1, "SYNCTYPE" = 25, "IDDEVICE" = 1555140855, "IDDATABASE"=6, "IDLOCALRECORD" = 477060711)
I do hope this issue can be resolved as I love this program and would really like the ability to sync my phone and laptop information.
Thank you for the support
Re: EPIM Syncing Key Constraint
I think clearing up the EPIM Cloud sync data in File->Database Management should fix the issue. If not, please forward us the sync log file. It can be found here: Tools->Options->Synchronization, Browse... and its filename should start with "EpimCloudSync".
