Red font is hard to read in dark theme.
Please hard code to a different color or allow user to specify color.
Font color overdue tasks
Re: Font color overdue tasks
Thank you, noted.
Absolutely, will do! Thanks.
Hi there,
maybe this bug is connected to a quirk I noticed since I updated my device (Realme 8 Pro) from Android 11 to Android 12 some weeks ago: The colours of the items have changed with this update, especially the brighter ones. See the following pictures with some test appointments, all tagged with a category associated with the colour yellow.
Screenshot from my Android 12 device, the shown colour is dark brown instead of yellow:
Screenshot from an Android 8 device (this is how it looked on my Realme 8 Pro with Android 11), the shown colour is yellow as it should:
The colour of the title bar is also different. EPIM 6.0.5 for Android, but also with some earlier versions. The widgets are installed in dark mode.
lk
lk
Thanks for the info, will have a look a this, as well.
On my end, I do not see same improvement yet in calendar list widget (v 6.0.9).
Is it still to be implemented or is it a hardware related thing on my phone?
Looks ok on our side, please see the screenshot below.
Try to remove and add the widget back on.Android version of EssentialPIM. Keep all your data in sync!
Hi, on my phone it looks like this with newly created widgets:
Overdue task is still much harder to read in Calendar widget (top) and easier to read in Task widget (bottom).
Please do same adjustment to Calendar widget as already adjusted to Task widget.
My setup:
WEPIM ProPort. 11.6.5 on Windows 10 <2-way sync over Wifi> AEPIM 6.0.13 on Samsung A52s 5G (Android 12 - One UI 4.1)
Thanks for the screenshots, will do out best to improve this.
