​symbol to show if tasks are visible in calendar
kdgdr
Has thanked: 9 times
Been thanked: 18 times
Post by kdgdr »
Please consider adding a symbol (an eye? a calender?) on the right hand side next to each task in the task module. Colour of the symbol would indicate if a task is set to show up in calendar or not. Ideally the symbol acts as a toggle switch, so user can change this "state" efficiently for several tasks while scolling to the listed tasks. Or even better: user can select multiple tasks at once and then change "show in calender" in batch, in the same way you can currently change category, priority, ... in batch for selected tasks.
Thanks in advance.
Kind regards.
Re: ​symbol to show if tasks are visible in calendar
Thanks for the suggestion, noted.
