Please add a keyboard shortcut to toggle tasks from 0 to 100% completion and vice versa. Ideally this shortcut works in task view and in calendar view (for both appointmens and tasks that show in calendar). This would allow a much more efficient completion of items.
Thanks in advance.
Kind regards.
keyboard shortcuts to mark selected tasks and appointments as completed
- Has thanked: 1418 times
Re: keyboard shortcuts to mark selected tasks and appointments as completed
There's the Ctrl+H shortcut for that and it can be adjusted in Options.
Ctrl+H is to Hide/Show Completed items, but that's not what I meant.
I meant a shortcut to switch the completion of selected items from "None" to "100%" and back. Now you have to select tasks/appointments in the calendar view one by one and for each you have to right-click and select Completion > "None" or "100%" from the context menu. A keyboard shortcut would me much more efficient to switch between "None"- or "100%"-completion.
Hope that clarifies.
Kind regards.
Kind regards.
Just use the space bar button then
Unbelievable: been an EPIM user for ages but did not know that. Thanks for the tip!
Might be a good idea to add this
- somewhere to the documentation/help?
- to Tools > Options > General > Shortcuts?
Yes, will probably do. Earlier we considered it as a pretty much general and well known shortcut, turns out that wasn't entirely true.
Been using Spacebar since I can't remember when for checkboxes in dialog boxes and such, but I never even considered trying it for Completion in WEPIM although there 's a relation with the task checkboxes. Must have been in a coma every time I used WEPIM: is that my fault or is that a bug that can be fixed in an upcoming release?
As you know we need to reproduce an issue first in order to fix it. So we may probably need to bring you down here first for analysis )
