Ctrl+K shortcut in calendar view
kdgdr
Has thanked: 9 times
Been thanked: 18 times
Post by kdgdr »
Ctrl+K keyboard shortcut only works in task view currently. Please activate it in calendar view as well, which would allow user to set visible tasks to not show in calendar.
Thanks in advance.
Kind regards.
Has thanked: 1411 times
Been thanked: 984 times
Re: Ctrl+K shortcut in calendar view
What does the Ctrl+K keyboard shortcut do in Tasks? I do not see it in the list of the default ones.
kdgdr
Post by kdgdr »
I mean the "Show in Calendar" functionality that can be found in the context menu of a task in Task View.
It appears to have been changed to Ctrl+N. I guess that change is very recent because it has been Ctrl+K for years.
Hope that clarifies.
Kind regards.
So you'd like the shortcut to work for the selected tasks in the sidebar?
kdgdr
Post by kdgdr »
Shortcut is:
  • Ctrl+K in WEPIM R10
  • Ctrl+N in WEPIM R11
Would like to use shortcut in Calendar view:
  • on tasks that are listed on right-hand side in task bar (WEPIM R10)/Side bar (WEPIM R11) to hide/show them in Calendar (middle part of screen).
  • on tasks that are shown in the calender (middel part of screen) to Hide them
[/list]
Kind regards.
Thanks, clear now.
