Hallo EPim developers
I am not sure if this needs a separate thread. The arrange by in notes seems to be bent again.
Version 11.0.2, Free
1:Arrange by 'Name' does not re-order the sub notes as expected.
2: Not sure what the 'Custom order' sorting setting should be. ( I'm still on free version !! )
3: The Notes tree shifts up or down when the arrange by is clicked.
I can't remember these problems on v 10.0, can try a parallel install test ( or VM ) if needed.
Thanks, Shaun
BUG: 9.10.6 Arrange by in notes appears to be broken
Re: BUG: 9.10.6 Arrange by in notes appears to be broken
This certainly needs a new topic as the problem is related to the Free version.
We're unable to reproduce the issue, please supply you post with some screenshots. Thanks!
