Mail - All Inboxes can't save columns
- Your V Gal
- Has thanked: 3 times
- Been thanked: 2 times
I love the feature to select which columns I want to show for ALL INBOXES + Individual Email accounts.
And there is a click feature to save my selected columns to all + Individual accounts. It says 'ALL INBOXES' which I presume is the summary at the top.
No matter what I select to save my favorite columns, the ALL INBOXES at the top will NOT save and reverts to the 3 column format so I have to select the columns I need to see each time. Am I misunderstanding this feature to save column layout or doing something wrong?
- Has thanked: 1433 times
- Been thanked: 995 times
Re: Mail - All Inboxes can't save columns
This seems like a bug, will be fixed in the next update. Thanks!
- Your V Gal
- Your V Gal
Please tell me that this bug on saving columns layout for ALL INBOXES is still in the loop to
be fixed.
be fixed.
It should have already been fixed. If not, the fix is coming with the next version update.
- Your V Gal
It is not fixed with the latest update -- thank you for fixing it soon!
- Your V Gal
I Wish!! Save selected columns works for rest of the folders but ALL INBOXES shows to save but it STILL does not work / Hold.
Really frustrating for me as I use the ALL INBOXES exclusively. This makes the 3rd update that doesn't fix the 'bug' Please help!
- Your V Gal
Previous posts on this same topic 2022 :
Mar 3 my first request regarding column layout for ALL INBOXES will not save/hold
Mar 4 admin 'seems like a bug will be fixed in next update'
Mar 25 bug still not fixed
[b]Mar 28 admin[/b] 'It should have already been fixed. If not, the fix is coming with the next version update'
Mar 28 It is not fixed with the latest update -- thank you for fixing it soon!
Jul 14 Update 11.0.1 it STILL is not fixed -- Save selected columns works for rest of the folders but ALL INBOXES shows the option to save but it STILL does not work / Hold. Really frustrating for me as I use the ALL INBOXES exclusively. This makes the 3rd update that doesn't fix the 'bug'.
Please advise when this 'bug' will be fixed.
Unable to reproduce the problem. Please make a short video demonstrating it, maybe we're doing something wrong.
- Your V Gal
1] My email always opens 'ALL INBOXES' with 5 columns [Priority/attachment/From/Subject/Mail Account
2] I add 3 more columns for a total of 8 -- exactly what I want ALL INBOXES to always show [and all of the other folders / subfolders too :
I add To / Received/Sent
3] I select 'Apply Columns To' and then 'ALL FOLDERS'
4] I can scroll down from ALL INBOXES to one of my email accounts folder and open it ... voila, all 8 columns show perfectly
5] without closing or minimizing, I scroll back up to open ALL INBOXES and the layout opens now with the original 5 columns...it didn't 'SAVE' my layout.
This is sooooo frustrating. Whoa! You found this bug before. How do I send a video? or how do I send multiple photos?
So now it's kinda the other way around. We were able to reproduce the issue now, thanks for the detailed list of changes. No video is needed anymore, will fix this in the next EPIM's update.
- Your V Gal
- Your V Gal
Hallelujah, the ALL INBOXES column layout bug is fixed!!!!
Thanks for the confirmation
