I have been using EPIM for more than ten years, with which I am very satisfied, however, I am missing something. I would like to be able to use a base like a notebook (without revealing all the modules), but if I hide modules, they are also hidden in my main base. would it be possible one day for EPIM to allow this setting, base by base?
Hidden modules
- PeCe
- Has thanked: 101 times
- Been thanked: 329 times
Re: Hidden modules
+1
Separate settings per database would be nice.
Not only for modules, but also for different settings per database. That would give new options, like
- one database as journal with only the notes module,
- another with notes and passwords for internet/password related data
- and of course a full database with all modules.
Of course this all can be done with the present databases, but still you have all buttons, same categories and the modules ordered in the same way. No option to differentiate the different databases.
- Has thanked: 1418 times
Re: Hidden modules
PeCe separate settings are now possible if you run several Portable version copies of EPIM. Each one of the copies will have its own set of settings.
