I was getting this error to begin with occasionally trying to send an email.
Now I'm getting it consistently when trying to add Notes to contacts -
The full error message is copied below.
So I "optimized" the database - didn't work, still got the error
Then I uninstalled and reinstalled Essential Pim pro (version 10.2.1)
I'm running EssentialPim pro on a Windows 10 computer - build 19044,
The Error message says I'm running a Windows 8 Workstation, version 6.2 Build 23FO
Still getting the error message. - Any ideas?
Error message:
violation of PRIMARY or UNIQUE KEY constraint "PK_HISTCONTACTS" on table "HISTCONTACTS"
Problematic key value is ("IDHISTORY" = 1)
Exception log with detailed tech info. Generated on 2022-07-05 8:11 AM.
Application title: MAIN.epim - EssentialPIM Pro
Application file: E:\Program Files (x86)\EssentialPIM Pro\EssentialPIM.exe
Application: EssentialPIM Pro 10.2.1 2022-04-01
Exception message: violation of PRIMARY or UNIQUE KEY constraint "PK_HISTCONTACTS" on table "HISTCONTACTS"
At trigger 'CONTACTS_AU1' line: 7, col: 83.
Exception address: 00778C40
Main thread ID = 6984
Exception thread ID = 6984
Object Logs:
08:10:38.244 SetViewMode OK
08:10:37.838 SetViewMode 4
08:10:32.763 DBOpen OK
08:10:32.497 SetViewMode OK
08:10:32.247 SetViewMode 0
08:09:20.638 DBClose OK
08:09:20.591 DBSave OK
08:09:20.591 DBSave
08:09:20.513 DBClose
08:09:20.513 DBOpen
08:08:38.591 DBOpen OK
08:08:38.513 SetViewMode OK
08:08:38.294 SetViewMode 0
08:08:38.138 DBOpen
08:11:03.411 ContEditDialog ContactEditPC PersonalTS ScrollBox1 RightPan FieldFrame6 ContentPNL TPanel TPanel NotesPan NotesMem RichViewEdit
08:10:54.119 ContEditDialog ContactEditPC PersonalTS ScrollBox1 LeftPan PhotoPan FieldFrame0 ContentPNL TPanel TPanel TagEditFrame RichViewEdit
08:10:39.916 MainForm FormPan TBXToolbar2 TopPan Top2TB FindCB
08:10:32.232 MainForm
08:09:20.935 StatusForm CancelBtn
08:08:51.419 MainForm FormPan TBXToolbar2 TopTB NewItemBtn
08:08:50.919 AddAccountsDialog CancelBtn
08:08:48.279 MainForm FormPan TBXToolbar2 TopTB NewItemBtn
08:08:40.919 SelThemeDialog OKBtn
08:08:38.279 MainForm
Memory: 32678; free 29535
Display: 2560x1440 pixels, 32 bpp, 96 PPI
Updates: 1
Last update: 2022-07-05
Error during execution of this program
- Has thanked: 1418 times
Re: Error during execution of this program
Please update to EPIM 11 (here you can download it: https://www.essentialpim.com/download-free), will it help?
