Hi there,
suddenly I donot get mail from amazon anymore into my inbox. Instead the mails appear in Spamfolder. Ok, maybe my mistake.
How can I tell EPIM that this is NOT spam (dont see anything like that).
How to take out an adress of spam filtering
Re: How to take out an adress of spam filtering
I have the same problem- for years now. Clicking on "not spam", reseting training data, sending log-file to Astonsoft- nothing helps so far.
I think Astonsoft is thinkig of the possibillity of whitlisting emails (see another topic here somewhere).
At the moment, the only possibility is making a rule: move Amazon from spam to inbox.
- Has thanked: 1419 times
You can add the recipient to a list of contacts and then enable the option to except messages from that particular recipient from being spam filtered.
@admin: This would work (adding to contacts). BUT: Here collide two different problems: 1) > sender to contacts- now it is excluded from spam. That´s ok. BUT: 2) When writing an new email, clicking "New Message!, "To", typing in "a...."- then I get the correct contact with "a". When adding Astonsoft, Amazon and others with "A...." to my contacts, this list gets longer and longer! There is no way to exclude contacts from the pulldown-list ("To").
Either you should implement a separate whitelist, or you should implement the option "exclude certain contacts (for example "Contacts which are NOT SPAM") from the "To" dropdown list!
Point taken, thanks.
