1048576, unable to reproduce this, unfortunately. I guess a more detailed screenshot is needed.
EssentialPIM 11.0 Release Candidate
- Has thanked: 1428 times
- Been thanked: 993 times
Re: EssentialPIM 11.0 Release Candidate
gjbth, good to know, thanks for the update!
lorymax, unfortunately, lots of details are missing in your report. Namely, the kind of filter you use, what's "permanently active", how you deactivate, etc. Probably a short video would demonstrate the situation better.
1048576, it still looks ok on our side. Please check what it looks like on yours when a dark theme is active.
I am attaching a video on what seems to me to be abnormal behavior when I close EPIM with active filters.
Could it also be the cause of the problem I have already reported?
viewtopic.php?p=123864#p123864
- 20220628_224448.mp4
- (3.21 MiB) Downloaded 160 times
I confirm the problem.lorymax wrote: ↑Tue Jun 28, 2022 9:54 pm I am attaching a video on what seems to me to be abnormal behavior when I close EPIM with active filters.
Last night I closed EPIM with active filters - as you can see in the video - and this morning I found the edited task as attached screenshots.
He only changed this. Only once did I find the same change in all float tasks with future start times. viewtopic.php?p=123864#p123864
- Has thanked: 10 times
- Been thanked: 31 times
Being in calendar module, having one calendar only with all my entries in it, I uncheck this calendar. So no calendar should be active/displayed. At least that's what I would expect.
But I still see a calendar (month view) and some entries in it. All of them are tasks. Most of them are completed tasks.
I wonder what I see there? Which calendar is displayed while no calendar is active?
What I would expect, is a blank screen with no calendar and no items in it.
Why is this?
Why is this?
I noticed this too. I tried to create two calendars and it works fine showing one at a time.poet-man wrote: ↑Wed Jun 29, 2022 7:44 pm Being in calendar module, having one calendar only with all my entries in it, I uncheck this calendar. So no calendar should be active/displayed. At least that's what I would expect.
Why is this?
I believe that for the tasks there has not been the possibility to choose in which calendar they should be displayed and therefore they always remain in view.
It would be useful to have in the tasks the possibility to associate to a specific calendar. The only generic option "view in calendar" also in my opinion creates confusion because they are always displayed.
Unfortunately my english comes from google translator. Sorry.
I have now seen another problem.
In Table view it displays nothing.
I opened the same file with epim Pro 10.2.1 and 11.0RC1 - I am attaching screenshots.
Does it happen to you too?
Maybe you are right and this is due to a program feature.lorymax wrote: ↑Wed Jun 29, 2022 8:19 pmI noticed this too. I tried to create two calendars and it works fine showing one at a time.poet-man wrote: ↑Wed Jun 29, 2022 7:44 pm Being in calendar module, having one calendar only with all my entries in it, I uncheck this calendar. So no calendar should be active/displayed. At least that's what I would expect.
Why is this?
However what I realised meanwhile, is, that this effect doesnot display all the time. Opening DB again later, suddenly the tasks I mentioned are not there anymore, or at least not all of them. Maybe this is due to wandering through all months to see whether there are more items there which should not be there.
Same difference in border thickness In dark mode.1048576, it still looks ok on our side. Please check what it looks like on yours when a dark theme is active.
- Video_2022-06-30_095642.wmv
- (3.05 MiB) Downloaded 168 times
EPIM Pro 12 Portable
password countdown is missing.
Before v11 I could doubleklick on password in password module, which displayed a 60 second countdown, to show the timeperiod during which I could paste password. This countdown seems to have vanished
lorymax, thanks for the video, we were able to reproduce the problem. Will be fixed in the final release version of EPIM 11.0. As for another one when tasks are shown with some unrecognizable characters, will have a look at it, as well.
poet-man, seems you see tasks in the calendar and since tasks do not belong to any specific calendar, they're displayed all the time (unless to choose not to display them in calendar, of course). And I can confirm the problem with the countdown timer missing in Passwords, will fix this. Thanks!
1048576, thanks, will try to somehow fix this (we're still unable to see that thick line on our PCs, though).
- Frizzell9
- Has thanked: 30 times
- Been thanked: 15 times
EPIM Pro User Since 2006
If you don't like this feature, you can add a shortcut to quickly activate the customized view bar which is not available now.lorymax wrote: ↑Thu Jun 23, 2022 8:21 pm I tried version 11.0 RC1. Very very nice.
In my opinion, it would be very useful to have a button in the top bar in the Tasks to directly activate the custom view bar. Or, even better,
always have the drop down menu of templates always available in the top bar without having to open the custom view bar every time. This second solution would really be the TOP for me!
Thank you
Better than nothing
Frizzell9 , that's not possible anymore.
lorymax, you can pin it so it becomes permanently visible. Or you mean you'd like to only see it occasionally time to time?
Yes, I know the permanent pin. It was just a small, unimportant idea.
I find the bar color a bit annoying and flashy in the dark theme, but even that is unimportant.
These little things don't have to steal time from the development of version 11 which I'm really enjoying
Thanks for your attention.
