pin mails to the top of the list
nath84
Has thanked: 16 times
Been thanked: 8 times
Post by nath84 »
hello the Epim team !
Would it be possible one day, to have the possibilty to pin mails to the top of the list ( like sms on smartphones or on web browser ?)
it woult be a really useful tool :D
thanks for all and long life to Epim <3
best wishes
Nathalie
Has thanked: 1121 times
Been thanked: 776 times
Re: pin mails to the top of the list
You can already do that by assigning messages a certain category and then sorting by that category, for instance.
nath84
Post by nath84 »
thanks for your answer,
it's better to have the mails at the top of the list, so we can see them when we open the mails ...
Steve Shank
Has thanked: 10 times
Been thanked: 4 times
Post by Steve Shank »
Not to negate your request, just to toss out how I handle this. I have a folder called Followup. I move whatever needs high priority checking into that folder and frequently check it. It might be better to have it on top, but it is conspicuous enough and whatever needs tending goes there. Some emails stay only a day, sometimes a month or more. All require followup. When handled I move them out to a better life elsewhere.
nath84 wrote: Mon Jun 20, 2022 8:56 pm thanks for your answer,
Ah, you mean you'd always like to see the pinned messages at the top regardless of the scrolling location. Thanks for the suggestion!
nath84
Post by nath84 »
[/quote]
YEEEESSSSS !!! that's it :) it would be really usefull !
thanks a lot for all your work !
nathalie
LaurenMyers
Post by LaurenMyers »
I want to know whether it is possible one day, to have the possibilty to pin mails to the top of the list and thanks all of you for giving me the suggestions. I would also like to help you by sharing https://www.topessaywriting.org/samples/environment website with you in which you can read essay samples for free.
