Connection Closed Gracefully
That's what happened. I updated to EPIM11b2 and AEPIMb3 yesterday. Synchronization completed succesfully. I tried two-way sync several times and everything was ok. Now I''m at another PC.
After first sync all my task were in thash. I restored everythind and tried to sync again and got "Connection Closed Gracefully". Log attached.
- EPIMCloudSync_2022_05_31_09_54_29.zip
- (35.89 KiB) Downloaded 430 times
EPIM Pro 11.8 Portable
- Has thanked: 1412 times
Re: Connection Closed Gracefully
Thanks for the log, will check it out.
Are you still getting this error on another PC? It seems you're using a proxy server, will there be the same error without proxy?
I can't check without proxy. It's corporate PC. I don't think the reason is our proxy itself. Sync goes fine while tasks are in trash. The error occurs only after I restore any task or create a new one. Video attached.
p.s. tried to sync at home again. works fine, but now I have 24 empty cloud calendars... approximately corresponds to the number of attempts of sync from corporate pc
p.s. it would be nice to select several calendars at once with Ctrl or Shift
- 2022-06-02_223329.png (4.04 KiB) Viewed 3330 times
- Video_2022-06-03_120327.wmv
- (3.75 MiB) Downloaded 179 times
Thanks for the update. If you try to sync other type of items, events of contacts, for instance, will there be the same "Connection Closed Gracefully" error?
Ok, will there be the same error with other taks, for instance or it only happens with the set that's shown on video?
It's hard to say. New task causes sync to hang. I tried to wait for 30 minutes and nothing happened.
- Video_2022-06-03_163402.wmv
- (1.91 MiB) Downloaded 183 times
Please attach a log file for such a sync.
This one I think
- EPIMCloudSync_2022_06_03_16_52_37.log
- (222.71 KiB) Downloaded 157 times
Perfect, thank you!
UPD: This problem will be fixed in the 11.0 Beta 3 version.
