EPIM Pro 10.2.1
I click on Go To Date, the dialog opens.
The fields are:
Date: 4/25/2022
0 Days Forward
Show in month view.
I click on the year, 2022 is highlighted. I press the Down arrow on the keyboard, the year changes to 2023. Similar issue with month (4) and day (25).
I'm certain this used to work as expected.
Go To Date Oddity
- Has thanked: 1119 times
- Been thanked: 774 times
Re: Go To Date Oddity
Not sure I understand the problem here. How would you expect it to work?
- ecsaltz
- Has thanked: 28 times
- Been thanked: 52 times
Agreed. Otherwise, to get to previous dates you have to type in the previous date or use the calendar icon.
PC Desktop: Window 10 Pro, 34 inch 4K monitor.
When I highlight 2022 and press the down arrow the year changes to 2023. This is not expected and I hope is not working as designed.
Now I see the issue - you cannot go back by clicking on the down arrow key. Thanks for the clarification, will be fixed in the next update.
- Has thanked: 20 times
- Been thanked: 142 times
this is issue is close to mine:
I just pressed CTRL+G for "go to date"
then i wanted to go BACK to 2015 and entered the date.
Doesn't work... why? Because the opperator was in the FORWARD mode
So if i know the date.. i first have to switch the opperator.
My wish:
either
a) if you enter the date, opperator will be overwritten (automaticly forward / backward)
or
b) possibility to got "PLUS x days" oder "MINUS x days" --> "go +10 days" vs. "go -10 days"
c) both
which leads me to my discovery: at the moment it's relativ to the day you are just editing (can be in the past / present / or future). But at this moment i have no preferenz if it is relativ "to today" or the "selected date"
My wish:
either
or
c) both
*including RC`s
*including RC`s
- PeCe
- Has thanked: 92 times
- Been thanked: 294 times
I do not know if there will be a new version for EPIM10 in which this problem gives problems. I agree the go to date now works difficult.
BUT
in EPIM11 beta2 your option A is included.
In EPIM11 beta2 that I am testing the operator is automatically adjusted (backward/forward) when you enter a date in past or future.
BUT
EPIM 11 Pro portable / Android EPIM 6.0
