Conversations View
Conversations View
I am evaluating Essential PIM (Windows version).
When I try to switch to "Conversations" (View -> Conversations) nothing happens except that the subject line moves right 1 or 2 chars.
My email is based on Google Applications. Do I have to set something in the Gmail settings (web)?
Best regards,
Marian Yordanov
Best regards,
Marian Yordanov
- Has thanked: 820 times
Re: Conversations View
you do not need to do anything else, EPIM should make Conversations of related emails. Looks like EPIM does not find related email so far. Please wait for EPIM to receive more email.
can you please export a couple of emails using (File-> Export->) and send them to me (PM on the forum would be fine). You can also write an email to yourself and reply to it a couple of times- would be fine as test emails.
Also, just in case, send me a screenshot of your Inbox with 'Conversations' switched on.
Hi Max
I am experiencing the same issue.
I exported 3 test messages to myself, put them in a zip file and sent them to you in a PM, but the message is stuck in my forum outbox
Please check with folder that has more emails. So far the feature was working fine for other users and there is no reason to believe otherwise.
The fact that emails with same subject are not treated as conversation is fine, as there are more parameters taken into account with real conversations.
I did try it in a folder with many messages - the messages I sent you were just samples.
I have sent you a PM with 2 screenshots of one of my inboxes with conversations on and off.
Maybe I'm missing something but I can't see any difference apart from the slightly larger gap in front of the subjects that was mentioned before.
Thank you! We reproduced the issue, will fix it in forthcoming 8.02
I can't get this to work. I replied to an email but I can't see that reply next to the original email.
I've turned on View/Conversations but there's no change to what is displayed.
Using 10.2.1
Using 10.2.1
- Has thanked: 1124 times
- Been thanked: 779 times
So far conversations only place incoming messages close to each other.
Which of course makes it *not* a conversation view! Mystifying...
Thanks for your help, though.
Depends on how you look at it
Although, we got your point, I think the feature will be expanded in the nearest future to include sent messages, as well.
"I think the feature will be expanded in the nearest future to include sent messages, as well."
At least it's reassuring to know that they have some good "ideas people" on the case...
