I was looking for an old email contact. In doing so, I noticed that apparently not all the emails were found.
Attached is a picture as an example.
When I save the mail address as a contact, I get more mails in the contacts overview than in the search.
Greetings
10.2.1 Advanced search does not find everything
Re: 10.2.1 Advanced search does not find everything
Try to sync your database over to the new one using EPIM Synchronizer, please. Will that make any difference?
- Has thanked: 14 times
- Been thanked: 7 times
Hi @admin
I have now synchronised the database once and run the search again.
Unfortunately, it makes no difference.
What is noticeable: 13 elements are found via the search (12 mails, 1 contact). However, epim finds 30 mails via the contact.
I think we'd need to get a copy of your database file in order to check the issue out. You can remove all the sensitive info from the copy of the database (just leave couple of email messages in it so that we could reproduce the problem) and forward it to me via PM. Thanks!
I've been trying for a while now to create an example for you or to delete data. Unfortunately, it is more difficult than I thought.
Do you have any tips for me on how I can make it easier?
Which action/option specifically you're facing problems with?
