AEPIM Note Synchronization
dream_weaver
Has thanked: 8 times
Been thanked: 6 times
Post by dream_weaver »
Windows 10.0.19043 Build 19043
EPIM 10.1.2
AEPIM 5.8.7
Recently notes edited on the AEPIM platform and/or the EPIM platform have not been synchronizing consistently. On first observation, toggling from 2-way to 1-way EPIM-->AEPIM forced the Notes on the AEPIM to match the EPIM
It has been switched back to 2-way mode.
Added a test note to the EPIM
Added a test note to the AEPIM
Neither note transferred to the other.
This was after doing a Data Optimization (which appeared to have helped initially.)
It was first noticed when checking some edited and rearranged notes between the two modules. It's easier to rearrange on the EPIM, but it has not been communicating the updates to the AEPIM.
Since no one else has mentioned this, it may be something on this end, but rectifying it is being elusive.
dream_weaver
Re: AEPIM Note Synchronization
After modifying a leaf on EPIM, the synchronization did not transfer to AEPIM.
Next, a leaf was added to an existing note on the EPIM side, and after the synchronization, the color changes I had done on the AEPIM to a bunch of other notes that got me exploring this transferred back from the AEPIM side to the EPIM database, and the modified note with the added leaf had transferred from the EPIM to the AEPIM side. <sigh>
dream_weaver
Several synchronizations later, the process has yet to actually synchronize updated notes.
The other modules appear to be doing just fine.
dream_weaver
Upgraded to v10.2
Four successive, minor alterations on either platform synch'ed.
dream_weaver
And then it is not synchronizing again.
This is happening intermittently here, and there doesn't seem to be a pattern I can identify on my end.
With nobody else chiming in, it seems that this must be an isolated issue.
Hm.. it could be. Please forward me here or via a PM couple of log files (one when sync is working and another when it's not), will check them out.
