Passwords : Add dates for created, modified and last used
Shaun
Post by Shaun »
Hallo essential pim,
This weekend I was in maintenance mode on my web logins. And what would have been useful would have been to have seen the dates for the password entries. Then I would know more if the login is still current, when it was updated and last used successfully.
Created : when the entry was created
Modified : Last modification date. Password or username only ??
Last Read : Would need to be triggered by the "Copy Username / Copy Password" buttons. ( Can Windows copy paste, Ctrl C be seen as an event ?? )
Thanks again, let me know if this suggestion makes sense, Shaun.
Has thanked: 1121 times
Been thanked: 776 times
Re: Passwords : Add dates for created, modified and last used
This is already there. You can right click on any of the password entries and choose Properties. Or you can enable the Created and Modified columns in the main Passwords view.
Shaun
Post by Shaun »
Hallo EPIM Admin,
Thanks for reply, YES, i've found the right click, properties. That helps, but I think the 'enable' columns is on the 'pro' version, I'm still stuck on the 'free' version !! Ciao, Shaun
Yes, these columns are only available in the Pro version.
