Tags Indicator and Names
VictorParkerPIM
Has thanked: 9 times
Been thanked: 51 times
Post by VictorParkerPIM »
When you TAG items, you can't look at the screen and see which items are tagged.
I want to suggest a few things that I think would improve the Tags feature.
First it needs some indicator that the item is Tagged.
when you hoover the mouse pointer over it, it shows the tag name.
There are other things that might improve the feature but needs more thought on them.
Re: Tags Indicator and Names
Which types of items are these? As usually you can enable the Tags column and see the tags assigned to an item in it.
VictorParkerPIM
Thanks for the reply, the items are text notes.
Where is the Tags column and how do I enable it?
I couldn't find anything in the help file or tools- options.
There's no Tags column in Notes.
VictorParkerPIM
Thanks, for the quick answer.
No problem. The suggestion is noted, of course. So some adjustments are in the plans.
