Access violation at address 014B8946 in module 'EssentialPIM.exe' Read of address 000003B4
Moderators: SolA, vvorl
Sadhaka
Has thanked: 96 times
Been thanked: 16 times
Re: Access violation at address 014B8946 in module 'EssentialPIM.exe' Read of address 000003B4
Post by Sadhaka »
При оптимизации оснасткой "Управление базой данных", во второй раз, вывалилась ошибка:
Code: Select all
Cannot perform operation -- DB is not open.
Exception log with detailed tech info. Generated on 18.02.2022 17:30.
 Application title: MY_WORK_BD_SYNC.EPIM - EssentialPIM Pro Portable
 Application file: C:\EssentialPIMPro\EssentialPIM.exe
 Application: EssentialPIM Pro Portable 10.1.2  18.02.2022
Exception class: EIBClientError
Exception message: Cannot perform operation -- DB is not open.
Exception address: 007788C4
Main thread ID = 16984
Exception thread ID = 16984
Object Logs:
17:29:10.628  DBSave OK
17:29:09.599  DBSave
17:28:12.935  DBSave OK
17:28:11.895  DBSave
17:25:41.783  DBSave OK
17:25:41.725  DBSave
17:15:34.263  DBSave OK
17:15:33.169  DBSave
17:03:10.121  SetViewMode OK
17:03:09.217  SetViewMode 3
17:01:47.554  SetViewMode OK
17:01:47.215  SetViewMode 5
17:01:41.481  DBSave OK
17:01:40.425  DBSave
17:00:33.215  DBSave OK
17:00:33.170  DBSave
16:45:33.205  DBSave OK
16:45:33.160  DBSave
16:30:33.207  DBSave OK
16:30:33.159  DBSave
17:29:49.850  ExceptionDialog OkBtn
17:29:20.512  StatusForm
17:29:18.299  DBManDialog FilePathEd
17:28:33.768  MainForm FormPan FormPan2 NotesForm PageControl1 TextTS RichEditFrame1 TabsTC RVPanel SRichViewEdit TPanel TRichViewEdit TRVTableInplaceEdit
17:28:23.845  MainForm FormPan FormPan2 NotesForm PageControl1 TextTS RichEditFrame1 TabsTC RVPanel SRichViewEdit TPanel TRichViewEdit
17:27:36.741  MainForm FormPan FormPan2 NotesForm PageControl1 TextTS RichEditFrame1 TabsTC RVPanel SRichViewEdit TPanel TRichViewEdit TRVTableInplaceEdit
17:27:28.244  MainForm FormPan FormPan2 NotesForm TreesTC NotesVT
17:27:25.740  MainForm FormPan FormPan2 NotesForm TreesTC NotesVT TagEditFrame RichViewEdit
17:26:46.734  MainForm FormPan FormPan2 NotesForm TreesTC NotesVT
17:26:32.847  MainForm FormPan FormPan2 NotesForm PageControl1 TextTS RichEditFrame1 TabsTC RVPanel SRichViewEdit TPanel TRichViewEdit
Memory: 8123; free 2353
PrevExceptions:
17:29:52.845  Cannot perform operation -- DB is not open
17:29:54.349  Cannot perform operation -- DB is not open
17:29:55.077  Cannot perform operation -- DB is not open
17:29:55.767  Cannot perform operation -- DB is not open
17:29:56.469  Cannot perform operation -- DB is not open
17:29:57.309  Cannot perform operation -- DB is not open
17:29:57.981  Cannot perform operation -- DB is not open
17:29:58.830  Cannot perform operation -- DB is not open
17:30:00.062  Cannot perform operation -- DB is not open
17:30:00.830  Cannot perform operation -- DB is not open
17:30:01.678  Cannot perform operation -- DB is not open
17:30:02.238  Cannot perform operation -- DB is not open
17:30:02.478  Cannot perform operation -- DB is not open
17:30:02.702  Cannot perform operation -- DB is not open
17:30:02.910  Cannot perform operation -- DB is not open
17:30:03.118  Cannot perform operation -- DB is not open
17:30:03.375  Cannot perform operation -- DB is not open
17:30:03.943  Cannot perform operation -- DB is not open
17:30:04.646  Cannot perform operation -- DB is not open
17:30:05.335  Cannot perform operation -- DB is not open
Updates: 1
Last update: 18.02.2022
Закрыть око ошибки не удалось. Пришлось снимать задачу в диспетчере.
Снова запустил оптимизацию.
И получил новую ошибку:
Code: Select all
database shutdown unsuccessful
failed to create database C:\EssentialPIMPro\Database\MY_WORK_BD_SYNC_restored.epim
Exception log with detailed tech info. Generated on 18.02.2022 17:41.
Exception message: database shutdown unsuccessful
Exiting before completion due to errors.
Exception address: 00778AC8
Main thread ID = 16224
Exception thread ID = 16224
Object Logs:
17:40:21.064  DBSave OK
17:40:21.017  DBSave
17:40:18.518  SetViewMode OK
17:40:16.962  SetViewMode 3
17:37:59.008  SetViewMode OK
17:37:58.371  SetViewMode 1
17:37:48.152  DBOpen OK
17:37:46.182  SetViewMode OK
17:37:44.976  SetViewMode 3
17:37:14.432  DBOpen
17:41:11.240  DBManDialog ComperssBtn
17:40:30.785  StatusForm
17:40:28.016  DBManDialog FilePathEd
17:40:20.513  MainForm FormPan FormPan2 NotesForm PageControl1 TextTS RichEditFrame1 TabsTC RVPanel SRichViewEdit TPanel TRichViewEdit TRVTableInplaceEdit
17:40:18.613  MainForm
17:39:50.017  MainForm FormPan FormPan2 TasksForm TSPWeekPlanner
17:39:44.016  TaskDialog Panel1 EndDateDTP
17:39:42.019  TaskDialog Panel1 DateDTP
17:39:40.012  TaskDialog PageControl1 TaskTS TitleEd RichViewEdit
17:39:39.008  MainForm FormPan FormPan2 TasksForm TSPWeekPlanner
Memory: 8123; free 2393
Updates: 1
На этот раз окно с ошибкой закрыть удалось.
В чём проблемы? Что надо сделать?
С уважением.
Sadhaka
Post by Sadhaka »
Дальнейшие попытки работать с оснасткой "Управление базой данных"
т.е. оптимизировать базу, постоянно заканчиваются описанными выше ошибками.
С уважением.
Has thanked: 1411 times
Been thanked: 984 times
Перезагрузите ПК и/или перезапустите ЕПИМ.
Sadhaka
Post by Sadhaka »
admin wrote: Fri Feb 18, 2022 3:55 pm Перезагрузите ПК и/или перезапустите ЕПИМ.
EPIM перегружаю постоянно, понимаю, что возможно будет восстановление работоспособности)).
В данном случае перегрузка не помогает.
С уважением.
Возможно, что-то случилось с базой. Попробуйте в новую перегнать с помощью EPIM Synchronizer: https://www.essentialpim.com/ru/feature ... nchronizer
Sadhaka
Post by Sadhaka »
Хотите верьте, хотите нет!
Но данная ошибка проявляется следующим образом:
1. Запускаю оснастку "Управление базой данных"
2. Запускаю "Оптимизировать".
и продолжаю верстать документы на втором мониторе
т.е. увожу курсор мыши на второй монитор и работаю над документами.
И вот тут-то и вылазит эта ошибка.
(Экран расширен на 2 монитора (несколько дисплеев в WinPro).)
Проверял десяток раз. Когда курсор мыши в пределах окна EPIM или 1-го монитора
- оптимизация проходит нормально.
Как только перевожу на 2й моник - всё! через некоторое непродолжительное время - ошибка!
Code: Select all
Exception log with detailed tech info. Generated on 18.02.2022 18:39.
Main thread ID = 19880
Exception thread ID = 19880
Object Logs:
18:36:04.916  DBOpen OK
18:36:02.551  SetViewMode OK
18:36:01.413  SetViewMode 3
18:35:30.222  DBOpen
18:38:44.151  StatusForm
18:38:42.016  DBManDialog FilePathEd
18:38:39.005  MainForm FormPan FormPan2 NotesForm PageControl1 TextTS RichEditFrame1 TabsTC RVPanel SRichViewEdit TPanel TRichViewEdit TRVTableInplaceEdit
18:38:33.513  DBManDialog
18:37:49.666  StatusForm
18:37:47.527  DBManDialog FilePathEd
18:37:44.477  MainForm FormPan FormPan2 NotesForm PageControl1 TextTS RichEditFrame1 TabsTC RVPanel SRichViewEdit TPanel TRichViewEdit TRVTableInplaceEdit
18:37:43.981  DBManDialog OKBtn
18:37:41.476  DBManDialog
18:37:02.403  StatusForm
Memory: 8123; free 2706
Updates: 1
И да, окно ошибки закрыть невозможно.
Только через диспетчер задач, снять задачу EPIM.
С базой всё нормально.
С уважением.
Что значит: "и продолжаю верстать документы на втором мониторе
т.е. увожу курсор мыши на второй монитор и работаю над документами."
С заметками в ЕПИМ работаете?
Sadhaka
Post by Sadhaka »
admin wrote: Fri Feb 18, 2022 5:06 pm Что значит: "и продолжаю верстать документы на втором мониторе
Нет.
Не важно в каком приложении работать, будь это Microsoft Office,
или просто файловый менеджер. Главное, что ошибка возникает когда фокус
с первого монитора уходит на второй.
Вот сейчас проверил на домашнем ПК (совершенно другое железо), он так же с двумя
мониторами. Ошибка такая же как и на рабочем ПК.
Выше писал, что ошибка возникает когда происходит оптимизация
в "Управлении базой данных", именно в этот момент.
Поясню, что когда запускаю оптимизацию она достаточно
длительна, и что бы не терять время, работаю на втором мониторе
не с EPIM (он занят оптимизацией базы), а с другим ПО, как пример
просто серфинг по Инету.
С уважением.
Спасибо, проблему с DB is not open воспроизвели, починим.
Немного отвлечённый вопрос, но важный для понимания процесса - а зачем вы оптимизируете базу вручную? ЕПИМ сам это делает когда нужно автоматом.
Sadhaka
Post by Sadhaka »
admin wrote: Sat Feb 19, 2022 10:00 am Спасибо, проблему с DB is not open воспроизвели, починим.
Годами ранее, ваши разработчики, словом те кто отвечали тут, говорили, что при переходе на новую версию EPIM необходимо чуть ли не обязательно оптимизировать.
И если помните о моей проблеме неадекватного увеличения базы после шифрования, то она не вернулась в прежние размеры автоматически, пришлось запускать оптимизацию вручную.
С уважением.
Много воды утекло с тех времён, ещё больше изменений было - та информация уже давно не актуальна :) ЕПИМ вам сам автоматически потом уменьшил бы размер после шифрования.
Sadhaka
Post by Sadhaka »
admin wrote: Mon Feb 21, 2022 2:57 pm Много воды утекло с тех времён, ещё больше изменений было - та информация уже давно не актуальна :) ЕПИМ вам сам автоматически потом уменьшил бы размер после шифрования.
Перешифровки базы не понадобилось.
Просто провёл оптимизацию в крайней версии EPIM 10.1.2 и размер вернулся к ~ 1,7 Гига.
Благодарю)
С уважением.
