Calendar Reminder Popup - show day of week
swwhit52
Post by swwhit52 »
Would it be possible to add "Day" (Monday, Friday, etc) to the list of optional display fields in the calendar reminder popup?
thank you
Has thanked: 1121 times
Been thanked: 776 times
Re: Calendar Reminder Popup - show day of week
You mean you'd like to have an option to see (enable) a new column specifically for that?
swwhit52
Post by swwhit52 »
Yes, exactly. Often I have to check a calendar to find which day of the week the reminder is for. This is not hugely important, but it would be convenient. Thank you.
Understood, thanks for the suggestion!
