Half year or quarter view ?
snaileater
Post by snaileater »
it has probably already been asked but ... :
Would it be possible to add an half year and quarter view in the Calendar section ?
That would allow "events stacks" (on "busy" days) to be fully visible and readable ...
That would be a nice (and easy ?) addition IMHO ...
Thanks !
Has thanked: 1411 times
Been thanked: 984 times
Re: Half year or quarter view ?
Thanks for the suggestion. Do you expect such views to be based on the Yearly view? If so, you can already choose the number of months to be shown in it in options.
snaileater
Thanks, i had skipped that option ...
It almost fits my needs. At that stage (and despite your indication) i just find it poorly ergonomic/convenient to set the 1st of January (or 1st of July - for "semester" views ...) at the upper left part of the screen though.
I'm maybe missing something.
If you need the first month to be any other one, just use the up/down keys on your keyboard.
snaileater
Yep that's true.
Thank you.
