Separation between events in calendar widget 2x2?
poet-man
Has thanked: 10 times
Been thanked: 31 times
Post by poet-man »
Does anyone know a possibility?
Say there is an event in widget on first of january. And another one on 10th of january.
Means more than a week in between.
So one could believe second event is not on 10th but on 3rd of january, because "Monday" as well.
To avoid this mistake, a separating line between that two events would help to indicate there is a longer period in between (or any other suggestion?)
Re: Separation between events in calendar widget 2x2?
You mean the Agenda view widget?
poet-man
Post by poet-man »
Yes that's what it looks like
......... an extra question added:
As described earlier, that widget tends to show wrong date in head bar. This morning it showed yesterdays date, which also means that "today" in listing of events is wrong, what is extremely irritating (Samsung Galaxy Tab S4/Android 10). In worst case scenario, one can believe to have an appointment, which doesnot really exist "today".
Among those several problems this widget presents, THIS one seems to be the worst. I do think this to be most urgent and should be solved as early as possible. Any chance?
Thanks for the clarification.
As for the issue - will attempt to fix it in the next update (seems to be present on just some of the devices).
poet-man
Post by poet-man »
@admin
Any possible suggestion as to my 'separation'-question?
We'd need to alter the UI a bit in order to make it look a bit more clear.
