Suggestion: Calendar widget
daho2018
Has thanked: 7 times
Post by daho2018 »
Hi.
Suggestion: I use the calendar widget, here are two ideas:
- Optinal display of tasks within the calendar, if the task does not contain an appointment, this should simply be displayed at the top.
- Adjustment of the font size. I would find it practical if you could adjust the font size. For me, I would set the size smaller to display more content.
Thanks and greetings.
Has thanked: 1115 times
Been thanked: 774 times
Re: Suggestion: Calendar widget
Thanks for the suggestion. Tasks can already be shown in calendar, just make sure to enable this in settings.
