Error executing program
pbchunt
Post by pbchunt »
This is the output:
Exception log with detailed tech info. Generated on 11/3/2021 1:15 PM.
Application title: Brad-11032021.epim - EssentialPIM Pro
Application: EssentialPIM Pro 10.0 Beta2 10/20/2021
Exception class: EIBClientError
Exception message: Invalid statement handle
select SelectedItem from ViewParamView where idView=3
Exception address: 0078C5CC
Main thread ID = 9876
Exception thread ID = 9876
Object Logs:
13:15:38.804 SetViewMode OK
13:15:38.177 SetViewMode 5
13:15:37.989 DBOpen
13:15:38.804 MainForm
Memory: 32688; free 26613
Display: 2560x1440 pixels, 32 bpp, 120 PPI
Updates: 1
Last update: 11/2/2021
I'm actually running Windows 11
Has thanked: 1412 times
Been thanked: 984 times
Re: Error executing program
viewtopic.php?t=7510
And in the future please post Beta-version related posts into the Beta section of the support forum.
pbchunt
Post by pbchunt »
This was happening even before I installed the upgrade to the beta version
pbchunt
Post by pbchunt »
I uninstalled the beta version and re-installed essentialPIM Pro. Set up new database and first restart got this error.
Exception log with detailed tech info. Generated on 11/4/2021 11:13 AM.
Application title: Brad11042021.epim - EssentialPIM Pro
Application: EssentialPIM Pro 9.10.8 11/3/2021
Exception message: Access violation at address 10028F0F in module 'gds32.dll'. Write of address 00000009.
Exception address: 10028F0F
Main thread ID = 3208
Exception thread ID = 3208
Object Logs:
11:13:39.203 SetViewMode OK
11:13:38.906 SetViewMode 5
11:13:38.734 DBOpen
11:13:39.203 MainForm
Exception stack
Stack list, generated 11/4/2021 11:13 AM
(00027F0F) [10028F0F]
Memory: 32688; free 28916
Updates: 1
Last update: 11/4/2021
I am running windows 11
Please capture a small video illustrating this. You can use this free tool: https://www.techsmith.com/jing-tool.html
pbchunt
Post by pbchunt »
Here is the screen recording: https://www.screencast.com/t/QDV0SbdLv
Thanks, please check if this is database dependent. You can temporarily rename or move your db file into another location so that EPIM could start without any database opened. Will there be the error message then?
pbchunt
Post by pbchunt »
I removed the database and opened a new one but did not set up an email account yet. It now opens every time without problem. My mail provider is mailbox.org and I synchronize email, calendar, and contacts through caldav and carddav. It initially sets up fine and downloads email fine. It's usually the second time I open EPIM when I get the problem. I tried limiting the sync to only when the program starts but that doesn't help either. I've wondered if it is the synchronization.
It just dawned on me, I have the same provider and setup on my laptop and I have no problems with EPIM on my laptop
My desktop is:
i9 10th gen : Aorus z490 elite mb : 32gb ddr4 2400 ram : M2 EVO Samsung 1 TB SSD : windows 11 : geforce gtx 1050 ti
Try syncing your DB that produces the AV error on EPIM's start into the new one using EPIM Synchronizer. That should fix the issue.
