Aktuelle Sprachdatei für alle EPIM-Versionen
- Has thanked: 21 times
- Been thanked: 184 times
Re: Aktuelle Sprachdatei für alle EPIM-Versionen
Update German | Deutsch v. 9.6.1
*including RC`s
*including RC`s
Update German | Deutsch v. 9.7.5
*including RC`s
*including RC`s
Update German / Deutsch 9.9.b1
- German.lng
- Update German / Deutsch 9.9.b1
- (120.94 KiB) Downloaded 354 times
*including RC`s
*including RC`s
*including RC`s
*including RC`s
Hi there,
as promised in viewtopic.php?p=118856#p118856 (although later than promised), here is my improved version of the German language file. Feel free to compare it with the current version, modify it, further correct it, enhance it... license for my part is CC0.
It's based on the language file which comes with v9.97 and is still far from being perfect, but I corrected many very common German spelling mistakes (especially capitalization and superfluous space characters), some typos and inserted many commas. Occasionally I found some better wordings, but only if I was sure that I got the meaning right. When in doubt, I left the strings as they were before.
lk
lk
- German.lng
- (121.13 KiB) Downloaded 435 times
Well, it might not be perfect, but it's a huge leap for a non professional translation.
*including RC`s
*including RC`s
ARGH,
shame on me, I forgot to attach the file
*including RC`s
*including RC`s
As I see, most (if not all) of my corrections are not included into this file, although my pseudonym is mentioned as a co-translator. Is there a reason for this or did go anything wrong here?
lk
lk
Hallo IK,
vielleicht kannst du mir einen Tipp geben wie man die beiden versionen unklompliziert nebeneinander legen kann.
Ich hatte dies mit Hilfe von Excel gemacht und bin dabei wahnsinnig geworden, da der Versatz nicht stimmte.
Wenn ich es recht in Erinnerung habe waren es meistens Wörter die ich mit Bindestrichen übersetzte.
Ich habe leider keine klare Erinnerung mehr, bin jedoch der Meinung gewesen, dass ich einige übernommen habe, bei manchen jedoch das ursprüngliche belassen habe. Manches geht auch auf die vorherigen Übersetzer zurück.
Als "Co-Translator" habe ich dich aufgeführt, da ich dies seit mittlerweilen 6,5 Jahren (Mai 2015) in meiner Freizeit getätigt habe.
*including RC`s
*including RC`s
- Has thanked: 17 times
- Been thanked: 8 times
Wenn ich (Tester) mich da ungefragt mit einem Tipp für Texter einmischen darf.Texter wrote: Sun Oct 17, 2021 12:06 am vielleicht kannst du mir einen Tipp geben wie man die beiden versionen unkompliziert nebeneinander legen kann.
Falls es nur um den Vergleich des Inhalts (also des Texts) der beiden lng-Dateien geht:
Mit einem Dateivergleichsprogramm klappt das sehr gut.
Ich habe es soeben ausprobiert, mit einem kommerziellen Programm und auch mit dem kostenlosen "WinMerge":
https://winmerge.org/?lang=de
--> Einfach die beiden zu vergleichenden lng-Dateien ins Programm laden oder ziehen. --> Schon werden Zeile für Zeile die Unterschiede angezeigt.
Hier ein Beispiel für einen Unterschied:
Tester wrote: Sun Oct 17, 2021 6:10 am Wenn ich (Tester) mich da ungefragt mit einem Tipp für Texter einmischen darf.![]()
Oh, cool. Das funktioniert wunderbar
*including RC`s
*including RC`s
Ja, WinMerge nehme ich auch gerne in solchen Fällen. Wer sowieso Notepad++ benutzt, kann auch das dortige Compare-Plugin nehmen, das funktioniert auch ganz gut.
Mit dem "Co-Translator" meinte ich nur, dass diese Zeile die einzige meiner Änderungen war, die in der angehängten Datei enthalten sind. Ansonsten habe ich natürlich keine Probleme damit, ich habe ja nur korrigiert und nicht die ganze Übersetzung gemacht. Mein Pseudonym habe ich sowieso nur eingetragen, um bei eventuellen Rückfragen erreichbar zu sein ("das hat lk geändert, frag ihn, warum er das gemacht hat").
lk
lk
*including RC`s
*including RC`s
*including RC`s
*including RC`s
